Is there a way to copy pasted an object (or a selection of objects) to all layouts? If I copy/paste a block to all layouts then I only need to edit the block once then all instances of the block on all layouts will be updated.
I got as far as this with Python, I’d like to know how to activate each layout iteratively, I don’t think my code for activate layout is working:
import Rhino
import scriptcontext as sc
pageViews = sc.doc.Views.GetPageViews()
for pageView in pageViews:
Rhino.Display.RhinoPageView.SetPageAsActive(pageView)
rs.Command('_Paste')
Any pointer would be greatly appreciated
Thank you in advance
for anyone who needs it, the script lets you select an annotation object on one layout and copy/paste it to all layouts in the Rhino doc.
obj = rs.GetObject("Select annotation on layout to copy to all", rs.filter.annotation)
rs.SelectObject(obj)
rs.Command('_CopyToClipboard')
rs.EnableRedraw(False)
for view_name in rs.ViewNames(return_names = True, view_type=1):
rs.CurrentView(view_name)
rs.EnableRedraw(True)
Hi David,
Thanks for the script!
Could you please help me with a slight modification?
I would like to be able to select multiple objects at once to copy to all layouts. Is this possible?
John
objs = rs.GetObjects("Select objects on layout to copy to all")
rs.SelectObjects(objs)
Since my last post, I have added a function that lets you select which layout(s) you want to paste into, rather than just paste to all layouts.
Let me know how this one work for you, cheers
here is the code:
import Rhino
#using the sticky library, show a message box with Tool Description for
#the first run. Message box is disabled afterwards
#Refer to Rhino Python sample files shipped with Rhino
stickyval = 0
if sc.sticky.has_key("pasteSelObjsToSelLayouts"):
stickyval = sc.sticky["pasteSelObjsToSelLayouts"]
if stickyval < 1:
rs.MessageBox(message='Copy Paste selected layout objects to selected layouts.', title='First Run Tool Tip', buttons = 0 | 64)
stickyval += 1
sc.sticky["pasteSelObjsToSelLayouts"] = stickyval
def pasteSelObjsToSelLayouts():
objs = rs.GetObjects("Select objects on layout to copy")
pageNames = []
pageViews = []
for i in sc.doc.Views:
if type(i) is Rhino.Display.RhinoPageView:
pageNames.append(i.PageName)
pageViews.append(i)
printLayouts = rs.MultiListBox(pageNames,
message='Layout to paste into',
title='Select layouts to paste into. Hold Ctrl+Shift for multiple selection. Hold Ctrl to add selection.')
for printLayout in printLayouts:
rs.CurrentView(printLayout)
rs.Command('_NoEcho _Paste _SelNone _Zoom _All _Extents _SelDup _Delete')
