By pressing ctrl+shift on the output, I can disconnect all the wires and connect it to output of other component. Is there a way all the connections get copied to output of another component without getting disconnected from the output of previous component?
You could interpose a parameter and move the multiple outputs to it, then connect or remove multiple inputs easily.
Thanks! That’s a great workaround!
Yes, that “output adapter” approach is what I use all the time.
// Rolf
It is very similar to how a Stream Filter is used:
connect_wires_2020Sep16a.gh (6.1 KB)
