Copy item from one layout to another
I am new to Layouts in Rhino. After years of exporting to Illustrator, I decided to knuckle down and see if I could finally get to grips with Layouts.
One simple (I hope) aspect alludes me.
I have a single file with multiple layouts, each containing a drawing of a separate component.
I need to copy drawing border elements from one Layout to another. I have used copy layer with objects, the problem being that the copy remains “associated” with the original Layout and will not display when I change to another.
There must be a simple solution I’m overlooking and would appreciate a nudge in the right direction. Many thanks.
Hi @MisterB,
Can you check your History setting?
Always record should be unchecked.
If history is set to “always record” this will happen with any set of objects since Copy is an History enabled command.
When you paste with no history, the objects are not associated with the original.
You can highlight the pasted geometry, and use the HistoryPurge command to remove the association with the original set.
If this is not the issue, please post a file here or send a file to tech@mcneel.com Attn Mary and include a link to the forum thread.
Thanks,
Mary Ann Fugier
