This is an old bug - predates Rhino 7 I think. A papercut, really:
When I use the COPY command and select YES for all three options (FromLastPoint=Yes UseLastDistance=Yes UseLastDirection=Yes), Rhino seems ‘slow’ - there’s a weird pause/delay between when an item appears on the screen and when I can click to place the next item. This makes it really slow to make a bunch of copies.
There is no delay when I select only one or two of the three command-line options.
I’m also not seeing that here.
Does it happen when you start a new file from a factory-default template, create a simple rectangle, and make a bunch of copies of that?
Also, please run the Rhino SystemInfo command and copy-paste the result here.
Windows 10 (10.0.19045 SR0.0) or greater (Physical RAM: 32Gb)
.NET 7.0.0
Computer platform: DESKTOP
Primary display and OpenGL: NVIDIA GeForce RTX 3060 (NVidia) Memory: 12GB, Driver date: 6-8-2023 (M-D-Y). OpenGL Ver: 4.6.0 NVIDIA 536.23
OpenGL Settings
Safe mode: Off
Anti-alias mode: 4x
Mip Map Filtering: Linear
Render version: 4.6
Shading Language: 4.60 NVIDIA
Driver Date: 6-8-2023
Driver Version: 31.0.15.3623
Z-Buffer depth: 24 bits
Total Video Memory: 12 GB
C:\Users\phcre\AppData\Roaming\McNeel\Rhinoceros\packages\7.0\SubstanceImporter\2.0.3\Substance.Win.rhp “SubstanceImporter” 2.0.3.0
