Copy display of original geometry
When I copy an object in V6, often times the original disappears during the copy (which is confusing as it appears to be a move rather than a copy, and you can’t use the original geometry to place the copy). Over here, extrusions and curves behave as expected, but surfaces / polysurfaces will not show during copy.
I’m still on 6.0.15034.13191, 2/3/2015 (new one is downloading slowly), so apologies if this is already handled.
EDIT - still seeing this in 6.0.15049.8591, 2/18/2015
Thanks,
Sam
Yes, thanks for the reminder - I’ve seen this as well- even Move shows the original until you drop it on the new location.
http://mcneel.myjetbrains.com/youtrack/issue/RH-29688
