Copy and paste error: missing patches
When I copy and paste anything from one Rhiono 8 instance to another Rhino 8 instance I get an error in the command prompt.
Error: missing patches
Any idea?
Hi Fernando - my guess is there is a plug-in involved - say RhinoCAM perhaps?
Never seen that with RhinoCAM… Cam_01* may be a camera/named view…
Yeah, just guessing… @fernando_rentas1 - can you please post the results from SystemInfo in Rhino?
The only plugin installed is V-Ray.
I do not have any issue with the geometry imported, it is just that the message keeps appearing per every geometry in the command prompt.
Hi Fernando -
Please post a 3dm file that we can check.
And maybe the results of SystemInfo?
Hi, was there any resolution to this issue?
I am having the same problem, and it just delays the process of copy/paste by quite a lot.
Me too actually.
Rhino 8 SR5 2024-3-12 (Rhino 8, 8.5.24072.13001, Git hash:master @ e3530849b75f00b2b977766a567ae29b055837e9)
License type: Commercial, build 2024-03-12
License details: Cloud Zoo
Windows 11 (10.0.22631 SR0.0) or greater (Physical RAM: 32GB)
.NET 7.0.0
Primary display: Intel(R) Iris(R) Xe Graphics (Intel) Memory: 1GB, Driver date: 7-11-2023 (M-D-Y).
Primary OpenGL: NVIDIA GeForce RTX 3060 Laptop GPU (NVidia) Memory: 6GB, Driver date: 11-2-2023 (M-D-Y). OpenGL Ver: 4.6.0 NVIDIA 546.09
OpenGL Settings
Safe mode: Off
Anti-alias mode: 4x
Mip Map Filtering: Linear
Render version: 4.6
Shading Language: 4.60 NVIDIA
Driver Date: 11-2-2023
Driver Version: 31.0.15.4609
Z-Buffer depth: 24 bits
Total Video Memory: 6 GB
C:\Program Files\Rhino 8\Plug-ins\Commands.rhp “Commands” 8.5.24072.13001
C:\Program Files\Rhino 8\Plug-ins\RhinoRenderCycles.rhp “Rhino Render” 8.5.24072.13001
C:\Program Files\Rhino 8\Plug-ins\RhinoRender.rhp “Legacy Rhino Render”
C:\Program Files\Rhino 8\Plug-ins\rdk_etoui.rhp “RDK_EtoUI” 8.5.24072.13001
C:\Program Files\Rhino 8\Plug-ins\MeshCommands.rhp “MeshCommands” 8.5.24072.13001
C:\Program Files\Rhino 8\Plug-ins\RhinoCycles.rhp “RhinoCycles” 8.5.24072.13001
C:\Program Files\Rhino 8\Plug-ins\RhinoCode\RhinoCodePlugin.rhp “RhinoCodePlugin” 8.5.24072.13001
C:\Program Files\Rhino 8\Plug-ins\Toolbars\Toolbars.rhp “Toolbars” 8.5.24072.13001
I would update your drivers, we have seen reports of Rhino 8 not working so well with NVidia drivers from 2023.
Still happening with the latest driver I’m afraid. Copy pasting and also when opening a file.
Are you also getting the “missing patches” messages, or is it just slow?
It’s slow when copying (no messages) and then when pasting I get thousands of Error: missing patches messages in the command line history.
What kinds of objects are you copy/pasting ? Can you post a sample someone can test?
I have the latest NVidia drivers and I even had an issue when opening files as it was mentioned above.
Hi -
@ helvetosaur - Literally anything…Text, polysurfaces, surfaces, meshes. It’s not happening in a fresh file. And the file that is displaying this problem is too big to post here. Is there another way I can share my file?
So it’s only that one file? Upload it to tech support here: Rhino - Upload to Support
Include a short description of the problem and a reference to this discussion thread.
Oh, and if you run the command Audit3dmFile, browse to the file in question and OK, it will generate a report. Can you SaveAs a text file and post the report here?
Now I could not open old files (a week old). Rhino hangs after I open the file and the error patch issue is happening while opening the file. This getting worse. I have the issue with multiple files.
Has a solution been found for this issue, I am now having the same “Error: unclear patches” when using copy/paste between two Rhino files
