Thank you for your investigation. Sadly this doesn’t work. I get the same output as bevor.
This is my js-code to get the points in threejs. Maybe someone see the error there?
_meshOutline(real_geometry){
let a = new Vector3();
let b = new Vector3();
let c = new Vector3();
real_geometry.geometry = BufferGeometryUtils.mergeVertices (real_geometry.geometry);
var obj = real_geometry;
const isIndexed = obj.geometry.index !== null;
const pos = obj.geometry.attributes.position;
const idx = obj.geometry.index;
const faceCount = (isIndexed ? idx.count : pos.count) / 3;
const clippingPlane = this._createIntersectionPlane(obj);
let positions = [];
for (let i = 0; i < faceCount; i++) {
let baseIdx = i * 3;
let idxA = baseIdx + 0;
a.fromBufferAttribute(pos, isIndexed ? idx.getX(idxA) : idxA);
let idxB = baseIdx + 1;
b.fromBufferAttribute(pos, isIndexed ? idx.getX(idxB) : idxB);
let idxC = baseIdx + 2;
c.fromBufferAttribute(pos, isIndexed ? idx.getX(idxC) : idxC);
obj.localToWorld(a);
obj.localToWorld(b);
obj.localToWorld(c);
var lineAB = new Line3(a, b);
var lineBC = new Line3(b, c);
var lineCA = new Line3(c, a);
this._setPointOfIntersection(lineAB, clippingPlane, positions);
this._setPointOfIntersection(lineBC, clippingPlane, positions);
this._setPointOfIntersection(lineCA, clippingPlane, positions);
//positions.unshift(positions[positions.length -1]);
const points = [];
const geometry = new BufferGeometry().setFromPoints( positions );
const count = geometry.attributes.position.count // your curve's buffer geometry
for (let i = 0; i < count; i++) {
const x = geometry.attributes.position.getX(i);
const y = geometry.attributes.position.getY(i);
const z = geometry.attributes.position.getZ(i);
points.push([x, y, z]);
return points;
_setPointOfIntersection(line, planarSrf, pos) {
let vec = new Vector3();
const intersect = planarSrf.intersectLine(line, vec);
if (vec !== null && !isNaN(vec.x) && vec.x !== 0 && vec.y !== 0) {
//let vec = intersect.clone();
//pos.push([vec.x,vec.y,vec.z]);
pos.push( vec.clone() );
_createIntersectionPlane(obj) {
var triangle = new Triangle();
var target = new Vector3();
const boundingBox = new Box3().setFromObject(obj);
var testpoint1 = new Vector3(1000,0,boundingBox.max.z);
var testpoint2 = new Vector3(-1000,0,boundingBox.max.z);
var testpoint3 = new Vector3(0,1000,boundingBox.max.z);
var testpoint4 = new Vector3(0,-1000,boundingBox.max.z);
var z1 = 0;
var z2 = 0;
var z3 = 0;
var z4 = 0;
var geometry = obj.geometry;
var index = geometry.index;
var position = geometry.attributes.position;
var minDistance1 = Infinity;
var minDistance2 = Infinity;
var minDistance3 = Infinity;
var minDistance4 = Infinity;
for ( let i = 0, l = index.count; i < l; i += 3 ) {
var a = index.getX( i );
var b = index.getX( i + 1 );
var c = index.getX( i + 2 );
triangle.a.fromBufferAttribute( position, a );
triangle.b.fromBufferAttribute( position, b );
triangle.c.fromBufferAttribute( position, c );
triangle.closestPointToPoint( testpoint1, target );
var distanceSq1 = testpoint1.distanceToSquared( target );
if ( distanceSq1 < minDistance1 ) {
z1 = target.z;
triangle.closestPointToPoint( testpoint2, target );
var distanceSq2 = testpoint2.distanceToSquared( target );
if ( distanceSq2 < minDistance2 ) {
z2 = target.z;
triangle.closestPointToPoint( testpoint3, target );
var distanceSq3 = testpoint3.distanceToSquared( target );
if ( distanceSq3 < minDistance3 ) {
z3 = target.z;
triangle.closestPointToPoint( testpoint4, target );
var distanceSq4 = testpoint4.distanceToSquared( target );
if ( distanceSq4 < minDistance4 ) {
z4 = target.z;
const middle = (z1+z2+z3+z4) /4;
var plane = new Plane( new Vector3( 0, 0, -1 ), 10 );
plane.set(plane.normal, middle);
return plane;
this code is just some prove of concept and could me optimized. I just added your code in the “_meshOutline” function. Bevor i just worked with the points in “positions” without loading it to a BufferGemeometry
