First time approach and this thing bugs me: how to apply the insertion plane to the block and bake it at the end. I have an impression that GH bar has to few components to complete it.
Once you have the block definition, you can create an instance which requires a base plane / insertion point / transformation…
If you cannot get it to work, share a grasshopper definition with some geometry.
It also helps to assign layers to all objects that go into a block.
like on most components…
You would want to assign the ‘3D’ layer to the instance, not the definition
