Is there a way to prevent this? I toggled flatshade on and off, but with no effect. thank you
It’s a polysurface build of degree 3 surfaces
What’s are your mesh settings in Options, Document Properties, Mesh?
Thank you @martinsiegrist - I set it to maximum with no effect
@martinsiegrist did a factory reset and it solved the issue. Thank you
@martinsiegrist what I found out is that there are no issues in shaded view only in rendered, is there any option to tweak these settings to have a smooth surface, as all my settings would be gone and I have to reset all of them one by one when I am starting from scratch, which is a nightmare. thank you
