Convert wireframe to solid
Hi dudes,
How can I translate Wireframe to Solid?
Can I do this directly or not?
I appreciate your help.
No probably not. You will likely need to proceed surface by surface. There might be some shortcuts, but without a model file to examine, it’s impossible to tell.
What if the geometry is too complicated?
Since the geometry is confidential, I cannot share it with anyone :frowning:
There’s no way to give you any real advice as there’s no information to base it on, sorry. Every model will be different. If you got a complex wireframe model from someone, chances are that the model actually exists in surface/volume form (nobody really models in wireframe). I would contact the supplier of the model and request that it be exported/sent in some more usable form.
