Hello, I have often to convert Step files into STL files. Is there a way to automate this converting?
regards Designer
Well, basically open it in Rhino and export it as STL. If you have a lot of files to do, a batch conversion script could be made… but… I think I would not want to do that, I would be checking every STEP on import and looking for errors/problems before exporting as STL… unless you know for sure that the STEP files are absolutely perfect.
–Mitch
