something like this
yup, that I understand, but what do you want to do with the non-numeric text?
Separate one from another (exclude non-numeric text). I believe Convert.ToDouble will give an error.
haa ok, no worries that can be easily done
Cheers
I know how to do “if” statements. But I still trying to get familiar with RhinoCommon
Thank you for help
@arten
Just to finalize this I added more robustness to it. It will ignore everything that is just letters, and all other crazy combinations engineers might come up with . See screenshot which is more self explanatory here… lol
PS: All the filtering stuff does not have to do with RhinoCommon at all though, pure string manipulation in C#
FilterMachine_ToForum.gh (8.6 KB)
and alas the code
private void RunScript(string layer, string illigalChars, ref object Points, ref object Heights)
List<Point3d> pts;
List<double> heights = new List<double>();
GetDataFromText(Rhino.RhinoDoc.ActiveDoc, layer, illigalChars, out pts, out heights);
Points = pts;
Heights = heights;
Component.Message = "Filer Machine";
// <Custom additional code>
public void GetDataFromText(Rhino.RhinoDoc doc, string layerName, string illegalChars
, out List<Point3d> pts, out List<double> heights)
List<Point3d> _pts = new List<Point3d>();
List<double> _heights = new List<double>();
Rhino.DocObjects.RhinoObject[] rhobjs = doc.Objects.FindByLayer(layerName);
if(rhobjs.Length == 0) throw new ArgumentException ("Could not find any text objects in given layer!");
for (int i = 0; i < rhobjs.Length; i++)
GeometryBase a = rhobjs[i].Geometry;
TextEntity text = (TextEntity) a;
string name = text.PlainText;
// Check if text contains letters
// Only process text which does not contain letters
if(name.Any(x => !char.IsLetter(x)))
// Remove all unwanted characters
string newString = RemoveUnwantedCharacters(name, illegalChars.ToCharArray());
if(newString == "") CovertStringToDouble(name, _heights);
if(newString != "") CovertStringToDouble(newString, _heights);
BoundingBox b = a.GetBoundingBox(true);
_pts.Add(b.Center);
pts = _pts;
heights = _heights;
public double CovertStringToDouble(string s, List<double> heights)
double result;
if(s.Contains(","))
string n = s.Replace(",", ".");
if(double.TryParse(n, out result)) heights.Add(result);
else
throw new ArgumentException ("Casting from string to double failed!");
else
if(double.TryParse(s, out result)) heights.Add(result);
else
return result;
public string RemoveUnwantedCharacters(string input, char[] allowedCharacters)
var filtered = input.ToCharArray();
return new String(filtered.Where(c => !char.IsLetter(c) && !char.IsUpper(c) && !allowedCharacters.Contains(c)).ToArray());
Cheers, and happy coding
