Hi Bill, you’re probably where running different code. The last one posted collects the text dot text and locations and pops up a dialog showing you that in a dialog from which you can save or copy to clipboard.
Here is one which collects the dot text and positions and prompts you to save to csv:
Hello, can I ask for help? I need simple scrip that will move text objects to Z coordinate that is the text itself.
Context: I received site survey that includes dots and each dot has text (for example “188.08”) that represents the height (Z coordinate) of the point. But all of them are in 0 at the moment.
Can a script move them in the appropriate Z height using the text as input?
def MoveDotsToTextHeight():
objs = rs.GetObjects(“Select text to transform”,0,preselect=True)
for obj in objs:
x, y, z, = rs.TextObjectPoint(obj)
z_coordinate = rs.TextObjectText(obj)
rs.TextObjectPoint( obj, [x,y,z_coordinate] )
