@stevebaer Any idea how to use the Py2to3 script to do this, or know of a the most efficient way?
"""Utility to convert py2 rhino-python files to py3 format"""
import os
import os.path as op
import shutil
from lib2to3.main import main # this is what 2to3 cli utility uses
# read sources
SOURCE_DIR = r"../Scripts/"
DEST_DIR = r"../python3/"
ITEMS = [
r"rhinoscript/",
r"rhinoscriptsyntax.py",
r"scriptcontext.py",
THIS_DIR = op.dirname(__file__)
ROOT_DIR = op.dirname(THIS_DIR)
print(f"{THIS_DIR=}")
print(f"{ROOT_DIR=}")
class SourceFile:
"""Context manager for a python source file"""
def __init__(self, filename) -> None:
self.filename = filename
self.source = ""
def __enter__(self):
with open(self.filename, "r") as rf:
self.source = rf.read()
return self
def __exit__(self, exc_type, exc_value, exc_traceback):
with open(self.filename, "w") as wf:
wf.write(self.source)
def replace(self, *args, **kwargs):
"""Replace string in source"""
self.source = self.source.replace(*args, **kwargs)
def prep_dest(source, dest):
"""Prepare a new copy of source files"""
if op.exists(dest):
print(f"Deleting: {dest}")
if op.isdir(dest):
shutil.rmtree(dest)
else:
os.remove(dest)
print(f"Updating: {dest}")
if op.isdir(source):
shutil.copytree(source, dest)
else:
shutil.copy(source, dest)
def convert_dest(dest):
"""Convert files to python3-compatible"""
print(f"Converting: {dest}")
main("lib2to3.fixes", args=["--write", "--nobackups", "--no-diffs", dest])
def apply_dest_fixes(dest):
"""Apply misc fixes to files"""
def apply_fixes(item):
item_name = op.splitext(op.basename(item))[0]
fixer_func_name = f"{item_name}_fixes"
if fixer_func := globals().get(fixer_func_name, None):
fixer_func(item)
print(f"Applying Fixes: {dest}")
if op.isdir(dest):
for dest_item in os.listdir(dest):
apply_fixes(op.join(dest, dest_item))
else:
apply_fixes(dest)
# Fixers ======================================================================
# function naming format is <file_name>_fixes
# e.g. scriptcontext_fixes applies fixes to scriptcontext.py
def scriptcontext_fixes(item):
"""Fix misc items in scriptcontext.py"""
with SourceFile(item) as sf:
sf.replace(
"import RhinoPython.Host as __host", "import Rhino"
sf.replace("doc = None", "doc = Rhino.RhinoDoc.ActiveDoc")
sf.replace(
"rc = __host.EscapePressed(reset)",
"rc = None # __host.EscapePressed(reset)",
def application_fixes(item):
"""Fix misc items in rhinoscript/application.py"""
sf.replace(
import scriptcontext
import Rhino
import Rhino.ApplicationSettings.ModelAidSettings as modelaid
import Rhino.Commands.Command as rhcommand
import System.TimeSpan, System.Enum, System.Environment
import System.Windows.Forms.Screen
import datetime
from . import utility as rhutil
""".strip(),
import datetime
import System
from Rhino.ApplicationSettings import ModelAidSettings as modelaid
from Rhino.Commands import Command as rhcommand
from System import TimeSpan, Enum, Environment
from System.Windows.Forms import Screen
""".strip(),
sf.replace(
"Rhino.PlugIns.PlugInType.None", "getattr(Rhino.PlugIns.PlugInType, 'NONE')"
sf.replace("filter =", "search_filter =")
sf.replace("filter |=", "search_filter |=")
sf.replace(
"GetInstalledPlugInNames(filter,", "GetInstalledPlugInNames(search_filter,"
def block_fixes(item):
"""Fix misc items in rhinoscript/block.py"""
sf.replace(
import Rhino
import math
import System.Guid
""".strip(),
import math
import System
import Rhino
from System import Guid
""".strip(),
def curve_fixes(item):
"""Fix misc items in rhinoscript/curve.py"""
sf.replace(
import Rhino
import math
import System.Guid, System.Array, System.Enum
""".strip(),
import math
import System
import Rhino
from System import Guid, Array, Enum
""".strip(),
sf.replace(
"Rhino.DocObjects.ObjectDecoration.None",
"getattr(Rhino.DocObjects.ObjectDecoration, 'NONE')",
sf.replace("ValueException(", "ValueError(")
def dimension_fixes(item):
"""Fix misc items in rhinoscript/dimension.py"""
sf.replace(
import Rhino
import System.Guid
from .view import __viewhelper, ViewCPlane
""".strip(),
import System
import Rhino
""".strip(),
def document_fixes(item):
"""Fix misc items in rhinoscript/document.py"""
sf.replace(
import Rhino
import System.Enum, System.Drawing.Size
import System.IO
import math
""".strip(),
import math
import System
import Rhino
from System import IO
from System import Enum
from System.Drawing import Size
""".strip(),
def geometry_fixes(item):
"""Fix misc items in rhinoscript/geometry.py"""
sf.replace(
import Rhino
""".strip(),
import System
import Rhino
""".strip(),
def hatch_fixes(item):
"""Fix misc items in rhinoscript/hatch.py"""
sf.replace(
import Rhino
import System.Guid
""".strip(),
import System
import Rhino
""".strip(),
def layer_fixes(item):
"""Fix misc items in rhinoscript/layer.py"""
sf.replace(
import Rhino.DocObjects.Layer
import System.Guid
from Rhino.RhinoMath import UnsetIntIndex
""".strip(),
import System
import Rhino
UnsetIntIndex = Rhino.RhinoMath.UnsetIntIndex
Layer = Rhino.DocObjects.Layer
""".strip(),
sf.replace("if idx is 0:", "if idx == 0:")
def light_fixes(item):
"""Fix misc items in rhinoscript/light.py"""
sf.replace("Rhino.UnitSystem.None", "getattr(Rhino.UnitSystem, 'NONE')")
def line_fixes(item):
"""Fix misc items in rhinoscript/line.py"""
sf.replace(
"Rhino.Geometry.Intersect.LineCylinderIntersection.None",
"getattr(Rhino.Geometry.Intersect.LineCylinderIntersection, 'NONE')",
sf.replace(
"Rhino.Geometry.Intersect.LineSphereIntersection.None",
"getattr(Rhino.Geometry.Intersect.LineSphereIntersection, 'NONE')",
sf.replace("Execption(", "Exception(")
def mesh_fixes(item):
"""Fix misc items in rhinoscript/mesh.py"""
sf.replace(
import Rhino
import System.Guid, System.Array, System.Drawing.Color
""".strip(),
import System
import Rhino
from System.Drawing import Color
""".strip(),
def object_fixes(item):
"""Fix misc items in rhinoscript/object.py"""
sf.replace(
import Rhino
import System.Guid, System.Enum
from .layer import __getlayer
import math
""".strip(),
import math
import System
import Rhino
from System import Guid, Enum
""".strip(),
def selection_fixes(item):
"""Fix misc items in rhinoscript/selection.py"""
sf.replace(
"Rhino.DocObjects.ObjectType.None",
"getattr(Rhino.DocObjects.ObjectType, 'NONE')",
sf.replace("def __FilterHelper(filter):", "def __FilterHelper(input_filter):")
sf.replace("if filter &", "if input_filter &")
sf.replace(
class CustomGetObject(Rhino.Input.Custom.GetObject):
def __init__(self, filter_function):
self.m_filter_function = filter_function
""".strip(),
super().__init__()
""".strip(),
sf.replace(
class __CustomGetObjectEx(Rhino.Input.Custom.GetObject):
def __init__(self, allowable_geometry):
self.m_allowable = allowable_geometry
""".strip(),
super().__init__()
""".strip(),
def surface_fixes(item):
"""Fix misc items in rhinoscript/surface.py"""
sf.replace(
import math
import Rhino
import System.Guid
from . import object as rhobject
from System.Collections.Generic import List
""".strip(),
import math
import System
import Rhino
""".strip(),
def transformation_fixes(item):
"""Fix misc items in rhinoscript/transformation.py"""
sf.replace(
import Rhino
import math
from . import view as rhview
""".strip(),
import math
import System
import Rhino
""".strip(),
def userinterface_fixes(item):
"""Fix misc items in rhinoscript/userinterface.py"""
sf.replace(
import Rhino
import Rhino.UI
import System.Drawing.Color
import System.Enum
import System.Array
import Eto.Forms
import math
""".strip(),
import math
import System
import Rhino
import Rhino.UI
import Eto.Forms
from System import Enum, Array
""".strip(),
sf.replace(
"Rhino.UI.ShowMessageIcon.None",
"getattr(Rhino.UI.ShowMessageIcon, 'NONE')",
def utility_fixes(item):
"""Fix misc items in rhinoscript/utility.py"""
sf.replace(
import Rhino
import System.Drawing.Color, System.Array, System.Guid
import time
import System.Windows.Forms.Clipboard
import math
import string
import numbers
""".strip(),
import time
import math
import string
import numbers
import System
import Rhino
from System import Array, Guid
from System.Windows.Forms import Clipboard
# import RhinoPython.Host as __host
""".strip(),
sf.replace(
"= __host.Coerce3dPointFromEnumerables(point)",
"= None # __host.Coerce3dPointFromEnumerables(point)",
def view_fixes(item):
"""Fix misc items in rhinoscript/view.py"""
sf.replace(
import Rhino
import System.Enum
import math
""".strip(),
import math
import System
import Rhino
""".strip(),
if __name__ == "__main__":
for item in ITEMS:
source = op.normpath(op.join(THIS_DIR, SOURCE_DIR, item))
dest = op.normpath(op.join(THIS_DIR, DEST_DIR, item))
convert_dest(dest)
