Convert optimized meshes from BESO Solver for the shell into curves
Hello everyone,
I’m in the process of optimizing a structure using the BESO solver in Karamba, and I’ve obtained this result.
Now, I want to separate the meshes with less density from the other meshes, essentially distinguishing the white meshes from the black ones. Can anyone provide some suggestions? Here is the Grasshopper file.
231109_v07_Topologie_Beso.gh (110.6 KB)
maybe you can try to select the mesh faces or vertices by their colour
otherwise does a mesh plane work?
Thanks for your reply, I was able to solve it using mesh|Plane component. :slight_smile:
