Convert mirrored points to "regular points"
I’m trying to connect points from two mirrored planes, but when I try to create a line between the points and the mirrored ones it shows that they are “Scaled1D” values. Does anyone know how to convert these to “regular” points. Essentially to render the points as if they weren’t mirrored.
The Mirror component has two outputs. You are looking at the wrong one. the Transform output contains a transformation matrix, and the Geometry output contains your points
