I’ve got a polyline that I want to simplify using the Convert command. It appears to me that specifying MaxLength=0 does not have the effect described in the manual. It should disable that constraint, instead it stops the whole operation.
I attached a Rhino with just one polyline. If you apply the Convert command on it with the default options -in particular MaxLength=0- then it does not convert the curve. Specifying a very large number does the trick.
I just want to inform you about this issue. The work-around is obviously very simple.
Kind regards,
Gero.
non_convertable_polyline.3dm (36.1 KB)
