Controls are hard locked to the xy plane
Hello, very new to rhino.
I’ve been working and I must of hit a key to set something off but anything I make is projected to the CPlane and it is interrupting the SoftEditSrf command that I am trying to use in my attached video.
Uncheck the Project box in the Osnap panel.
It is already un-checked. Anything I move or place is projected to where ever the cplane is and I have no control of moving objects on the z-axis
Hi Owen - SoftEditSrf has a constraint option at the command line. Most likely you want SrfNormal.
My controls are still locked to the CPlane and I still don’t know how to undo it.
Hello- please read my post above.
Whoops, I had to change the constraint option after i chose the base point. Everything works fine now thank you.
