Controlling surface values from external app/script
I am looking for the easiest way for controlling values of points (x,y,z) which create a surface. Ideally, I want to have a web application or Desktop application where I can change the points values, and the surface will change accordingly.
What is the easiest way to do so? Are there any plugins I can use?
Thanks
Eli
Maybe using Rhinocompute with a python web app (e.g. flask or pyramid) ?
https://www.rhino3d.com/compute
Thanks! Seems like I need to set up a server and stuff, which I am not familiar with. Any other options? If not I’ll try to
Humm… hard to say … what are you trying to do exactly ?
My goal is to provider a designed UI for “regular” people, where they can change the z parameter of each point, and then can see the surface changes accordingly. It is for an exhibition. I thought maybe there is just a file that I can change, or a serverless API so I can externally communicate with the software.
A grasshopper slider ?
Have no idea what this is! A plugin?
:slight_smile:
https://www.rhino3d.com/6/new/grasshopper
