# Control Spacing of circles in Hex Grid
**URL:** <https://discourse.mcneel.com/t/control-spacing-of-circles-in-hex-grid/86199>\
**Category:** Grasshopper\
**Created:** [July 15, 2019, 11:37am UTC](https://discourse.mcneel.com/t/control-spacing-of-circles-in-hex-grid/86199 "2019-07-15T11:37:29Z")\
**Posts on this page:** 1\
**Showing post:** 9
<div class="post-metadata">
**Author:** ![Joseph\_Oster](https://sea3.discourse-cdn.com/mcneel/user_avatar/discourse.mcneel.com/joseph_oster/32/549124_2.png) [@Joseph\_Oster](https://discourse.mcneel.com/u/Joseph_Oster)\
**Post date:** [July 15, 2019, 5:09pm UTC](https://discourse.mcneel.com/t/control-spacing-of-circles-in-hex-grid/86199/9 "2019-07-15T17:09:23Z")
</div>
> [@courteneykemp](#):
> I am just using an 18" long straight curve
So you don’t need Map Srf at all. That’s what I figured… 🤦‍♂️
 ![CPP1%207-15c](https://global.discourse-cdn.com/mcneel/uploads/default/original/3X/5/8/58344f4628ecc79c6616416f68abb798bf1c8328.png)
[CPP1 7-15\_2019Jul15c.gh](https://discourse.mcneel.com/uploads/short-url/nRDwi3GJUIMW0M3bYnQcmGzhwqw.gh) (30.3 KB)
P.S. I didn’t actually cut the holes in the surface but you have three options:
1. Boundary Surface using the perimeter curve and circles; this is often the best option for planar surfaces, but will be extremely slow for ~14,000 circles in this case!.
2. SrfSpilt is probably even slower. Both might fail before they finish.
3. Bake the surface and circles to Rhino and cut the holes there.
I already mentioned this old thread in your duplicate thread:
> [@Multiple Attractors with Points / Circles & Cutting Circles out of a Surface](https://discourse.mcneel.com/t/multiple-attractors-with-points-circles-cutting-circles-out-of-a-surface/55772):
> Hi, I’ve created a grid of circles that I would like to scale using attractor points. I’ve used a Minimum component to limit the effect / operating range of the attractor. I haven’t been able to figure out how to add additional attractors to the definition - ideally I’d like to add multiple points. Many thanks in advance, [attractors\_circles.gh](https://global.discourse-cdn.com/mcneel/uploads/default/original/3X/7/c/7c96bb9df9af99a6eb2203db4ce917dcd258300a.gh) (10.2 KB)
Some of it is irrelevant for planar surfaces but there is a discussion of option #3 (bake and cut in Rhino) showing it can be _ **MUCH FASTER** _ than Grasshopper.
Oh, there is a fourth option: cut holes in a panel that is ~1/10th the size (1/10th the number of holes!) and then copy/move it nine times.
_[View the full topic](https://discourse.mcneel.com/t/control-spacing-of-circles-in-hex-grid/86199)._
