For some reason when I “control shift click” a surface with autocplane enabled I get the “LAST COMMAND” instead of the autocplane. I’m thinking that I have a setting wrong but can’t find anything that looks like it would affect the autoplane command.
I also get the “LAST COMMAND” when the autoplane is disabled.
Hi Paul - ctrl(cmd)-shift should always just sub-object select as far as I know, (unless filters are set to select sub objects, in which case it will select top level ones). Are you using a regular mouse?
