The role model for this should be MODO’s Falloffs. Linear, Cylinder, Radial, Brush and 6 or 7 other types. The Falloffs have control handles so you can manipulate them, reverse direction, alter intensity and so on.
Hi asdfsjal, Softmove command or cageedit are not useful in this case.
This is a more direct approach when you select one point it affects also the neighboring points like on the example picture. Thanks
There is a difference, SoftEditSrf is quick to use, you don’t need to activate and select control points and other steps. It would be even faster with shift selection add points possibility, some colors and a dialog box that could practically, integrate this two in one powerful command.
