hiiii!! I have a problem with a surface. I can`t add more control point in it.
I had added control points before, but now, when I want to add more I use the command for adding them and when I press intro the control points just don´t appear.
This is the surface and its properties:
Tried rebuild surface
command? and then you can have your control points on by hitting Points on or F10
moved to Rhino for windows
From Uncategorized
Sorry, I don`t undestand, what do you mean?
Hello - try the Check
command on this - what does that report?
I can´t use that in the surface
