Control point weights
When working with Bézier curves, why do many modelers prefer to increase the degree of a curve to achieve a desired shape, rather than adjusting the weights of the control points? After all, using weights can often produce the required shape while keeping the curve’s degree lower. Are there any limitations or drawbacks to using weights that make increasing the curve’s degree a preferable approach? Furthermore, how does modifying the weights of a Bézier curve’s control points affect the quality of the resulting surface?
Weighted control points destroy the smooth and consistent nature of the Bezier surfaces. Even if a Bezier surface has just a single weighted control point, it will not match properly to the adjacent surface (or vice versa), unless you increase the total number of control points or add extra spans.
A surface created from a weighted curve will also suffer from the same issue.
