This is what I’ve got. I can make the two balls move (the distance between them is constant) along the line.
The dimension is set to show the distance between the cone and the closest ball.
I can add more cones.
Is there a way to control directly this dimension? if I want to set an exact dimension between a cone and a ball (knowing that it will affect all the other positions).
Thanks
Circle-re-v5.gh (31.9 KB)
