Contouring with Record History
Hello! I recently learned the ‘record history’ command.
I can see how easy it is to transform the child(?) surfaces or breps
by moving the parental curves’ vertices.
But one thing, could it be possible to use this command with contouring the geometry?
(For ex, if i use gh. and contour the breps,
i can see the contour curves change interactively as i change my brep in my rhino viewport.)
Just curious,
the progress with contouring in gh. seems a bit similar to the record history in rhino.
Thank you for your help! And have a nice day!! :slight_smile: :slightly_smiling_face:
Hello - in plain Rhino, the inputs to a command are the ‘parents’ when used with History, and any geometry that are generated are ‘children’. Currently Contour does not support History. But a set of contour curves made in GH should certainly update if you modify the target objects - are you finding that it does not?
Oh, i wanted to know if contour supports the history command.
Thank you for letting me know! :slight_smile:
