Here is a somewhat strange bug. One area of this trimmed surface does not respond to Contour, Section or Project. The remainder of the surface is okay. See attached file. The red line is perpendicular to the contour planes. I also created a line in the location of the missing contour in the front view, and tried to Project it onto the surface - nothing. Also tried using Section in the same location in the front view - nothing.
I’ve seen imports from Maxsurf behave in this manner. For some reason it is OK to stack control points in Maxsurf to create chines and such but when imported to Rhino that technique can cause a problem. There is a term that refers to just that, ‘degenerate surface’ I think it is. That is usually referring to points forming a ‘singularity’ but think it can apply to the chines. I’ve split Maxsurf hull surfs along the chine isocurve as a workaround.
Solved the problem using RebuildEdges on the trimmed surface. No need to use InsertKnot. Turned on control points for the original trimmed surface and the one with rebuilt edges and there are no obvious differences.
Added: Relaxing the absolute tolerance from 0.001 to 0.002 also solved the problem with the original surface. RebuildEdges moved the surface by up to 0.0045 so that change in the surface may have solved the problem.
@pascal You may have missed from my edit of a post above: [quote=“davidcockey, post:6, topic:19066”]
[/quote]
@pascal I finished that project almost two months ago. The surface was probably created with NetworkSrf, though Patch with a “starting surface” may have been used. It also may have been rebuilt, had control points deleted, or otherwise modified after being created. The example I posted was a trimmed and shrunk version of a larger surface which had the same problem.
