Contour command generates fragmented curves
I am having problems creating a contour map of a terrain surface. The surface is very large, about 4000x6000m in size. When I try to create the contours, the curves always come out split with large gaps between them, not connected to each other. See image
I have already tried to create the contours using Grasshopper, also with the Intersect command and cutting planes. As well as splitting the surface into several smaller pieces and also using a lower unit tolerance. I hope someone can help me.
Regards, Til
This is typical behavior when contouring complex NURBS surfaces with a lot of points. If you mesh the surface - or use the original DEM point data to create a mesh instead of the surface - and then slice the mesh, you should then get complete curves.
It worked. Thank you very much!
