Continuous Cylinder Arch
Hi Guys,
Is there a way to make the cylinder continuous and not having a short segments? I tried to make the center curve join and simplify before extruding into a pipe but it didn’t work?
Continuous Cylinder Arch.gh (13.3 KB)
Please see attached gh file.
thanks,
Hey,
In your file, you’re doing a pipe on each small segments, separately.
Here’s a possible solution : recreating the curves before piping.
Note that with nurbs, the line isn’t really touching the points, but it might fall within your tolerances.
Continuous Cylinder Arch.gh (13.9 KB)
Thank you so much Antoine, cheers.
Hi Antoine,
The pipe is good! just a small thing, is it possible to show the outer outline?
thanks,
Hi Antoine,
All good, I managed to sort it out, thank you!
