If I use the long surface edges as rails and the adjacent
edges as sections for sweep2, I don’t get continuity options unless I rebuild. Why?
Version 6 SR13
(6.13.19035.17431, 2/4/2019)
no tangent options.3dm (171.9 KB)
Version 6 SR13
Hi Peter - this looks like a bug to me - you do not get continuity options if the section curves are rational - in this case though the upper fillet is rational the trim on it is not so I would not expect that restriction. And if you DupEdge
to get the free curves as inputs, then you do get the options as expected. I’ll poke some more but I think this is not designed behavior…
https://mcneel.myjetbrains.com/youtrack/issue/RH-50771
Thanks
