ContinueInterpCrv from the other end?
Is there a function to continue and interpolation curve from the end at which you began the curve? I find myself having to construct a new curve with the same tangent and then using Join.
Hi Evan - continuing should pay attention to the end of the curve that you pick to continue.
Hi Pascal,
Thanks for the quick reply. It seems when I execute the commant ContinueInterpCrv on an interpolation curve, there are no options to select WHICH end I want to continue from. It is always the end from which I left off.
Hi Evan - try starting the command with no selection, then, when you’re prompted for a curve, click on it at the end you’d like to continue.
Any luck?
Got it.
Thank you pascal.
