Continuation of the surface with FilEdge
After the chamfer there is an open area. It seems that the component should continue the surface, Rhino has the same problem. How to deal with it?
Your question is that there should be a place to be filled along with chamfer? Should they be a place to be made separately?
I don’t know why you’re going to use GH for this, but there are probably a number of solutions depending on how you model this.
Think about whether you need GH for this work. Sometimes manual work is much efficient and faster.
FillFloorGapsAfterChamfer_re.gh (9.9 KB)
I understand. But now I need exactly GH. Yes, I need a fill. It is better if the bottom surface is uniform (not in parts). I can’t see your file right now, later …
Cool! Wonderful thought! Thank! :smiley:
