Content Cache Component: Failed Update Error
When using the content cache in this definition, it fails to bake a specific part at {0} (0) and displays the message “Failed to update Model Curve at {0} (0).” However, manually baking it from the model object component works fine in the Rhino Model. Is there a solution to automatically bake all the content using the content cache component? Thank you.
RH8 Create Column Grids (02).gh (40.0 KB)
This is a complicated example to look through. Can you send the 3DM model that goes with it?
We can start there.
Hi Dani,
I think these Content Cache components didn’t upgrade properly, try deleting the existing ones and place new cache controllers.
Hi Japhy,
That worked
