Containment circle
I am trying to calculate the minimun circle that contains a given generic flat curve but the strategy 1 used is generating a circle that insersect the curve and its not tangent ( it creates more than 2 intersections )
i also tried to use k2 but i am not very good with K2 and apparently the curve collide is not working when the curve to collide ( passive curve ) is contained inside the colliding curves , or maybe i am arranging it wrong. Anyway the shrinking of the lines continue way beyond tangency and it becomes zero
CONTAINMENT CIRCLE - CIRCULAR BOUNDING BOX.gh (20.3 KB)
My goal is as said to find the minimum tangent circle that contains a given close crv
The strategy 1 is generating tons of lines and it looks very demanding especially when i have several curves to process.
I have the feeling that K2 is the way to go but i don’t know how to set it up.
any suggestion is appreciated
thanks
Hello
you have some examples here, but they work with points and so don’t use the tangent or curvature.
Many thanks Laurent , you are always helpfull. i really appreciate !
@laurent_delrieu this is a good starting point , i will divide the curves in several points and i should have a good approxition, as i far as i can see on the sent thread this challenge is way more complicated than i expected …i wonder if K2 could be helpfull on solving this problem ?
There are co-circular and co-spherical goal options.
Not calling it a solution - 'can work, but it can also be probably prohibitively expensive (point density):
CONTAINMENT CIRCLE - CIRCULAR BOUNDING BOX.gh (11.9 KB)
thanks a lot @René_Corella , you proposal seems to generate reliable results for high nr. of subdivision but you are right , quite dememding under a computational point view.
anyway thanks a lot for spending the time to look over it , I have learnt something new from your script :wink:
