Container Toolbars
I cannot place the toolbars as in V7 , seperate, but not freely flkoating, as single entities below the top as per the screenshot attached
Hello- that should work - you can drag ‘floating’ toolbars by the four-dot grippers
Move them to the area of the target zone until you see the blue rectangle
then drop and adjust as needed.
You may want to save the configuration as a window layout, to be able to restore it any time, in the Window menu > Window Layouts.
Continuing the discussion from Container Toolbars:
Hi Pascal, this is a reply to your comments yesterday, my installation shows blue rectrangles “around” the place , where i move the toolbar to:
grafik
That’s what should happen, yes.
Then, move the mouse cursor into one of those blue boxes and release the mouse button.
Thank you, not really evident - thanks!
