Construct a matrix from points
Hi, I’m a beginner in Grasshopper and Rhino. I want to construct a 33 mathematical matrix from the coordinates number of 3 points captured from Rhino file.
It’s something like this, but what I need is the 3
3 matrix containing all the xyz coordinate information.
Could anyone tell me how to do that? Thanks so much!
Is this what you’re trying to achieve?
3matrix.gh (9.0 KB)
Thanks.
But I mean a mathematical matrix containing the coordinate numbers.
Easiest would be to use the Points To Numbers component:
Thanks a lot, that’s what I need.
I actually want to do the contrary, use that matrix to create a list of point…
Then use the inverse component of Points to Numbers which is called Numbers to Points.
