Constraints Panel too small
When I open the constraints panel in a new Rhino document, the white space where sketches and constraints are displayed is not using the full space of the panel. As soon as I add the first constraint, a scroll bar appears and I can manually pull down the bottom edge of the white space.
I think the white space should make use of the full size of the panel by default or around 3/4 of the size available so there is still room for some of the constraints details or settings at the bottom of the panel.
Hi Martin,
thanks, I’ve added RH-73546 Constraints UI area should be as large as the panel by default
