Connection between two walls that makes one of the walls black
hi,
A connection between two walls that makes one of the walls black in the model and plan without a hatch fill
Hello @11170,
Please, could you send me the file? Which VisualARQ and Rhino versions are you using?
see attached file
בדיקת קיר.3dm (563.1 KB)
and i use rhino 7 and
Hello @11170,
I checked your file and updating the wall solves the problem. Is this working for you? If it doesn’t, please let me know your computer specifications. Are you using any virtual machine such us Parallels?
Wall
It only works for a short time and comes back after working on the model, it usually happens in the connection between rounded walls and straight walls that the connection between them at a sharp angle.
computer specifications:
Hello @11170,
Does it change after running a command? Which one? Please, could you send a video, just in case we are missing something?
I have already reported this issue, so I’ll keep you updated about it. Anyway, if you find out more about this issue, please, let me know.
