Connection between low wall and high wall creates a space in the wall, can it be solved, it is important to note that the high wall is extended to the roof
Hello @11170,
You can solve this by giving the extended wall a bigger height before extending it. Take a look to this example:
Anyway, this should be fixed, so I’ll add your vote to this issue.
It works great, thanks for the quick response
