I’m trying to run this script in a python script to simulate a robot:
Run the following code in VS CODE
import paho.mqtt.client as mqtt
import time
broker = "mqtt.eclipseprojects.io"
port = 1883
topic = "robot/signal"
client = mqtt.Client()
client.connect(broker, port, 60)
client.loop_start()
message_count = 0
try:
while True:
payload = f"Simulated message {message_count}"
client.publish(topic, payload)
print(f"Published: {payload}")
message_count += 1
time.sleep(1)
except KeyboardInterrupt:
client.loop_stop()
client.disconnect()
Now I woujld like to listen to this in Grasshopper and expire a pytho ncomponent everytime it fires.
For this I use this code.
import Rhino
import Grasshopper
class MyComponent(Grasshopper.Kernel.GH_ScriptInstance):
def __init__(self):
# Initialize instance variables.
self.mqtt_client = None
self.message_data = None
self.setup_mqtt()
def setup_mqtt(self):
# Create and configure the MQTT client if it hasn't been initialized.
if self.mqtt_client is None:
self.mqtt_client = mqtt.Client()
self.mqtt_client.on_connect = self.on_connect
self.mqtt_client.on_message = self.on_message
self.mqtt_client.connect("mqtt.eclipseprojects.io", 1883, 60)
self.mqtt_client.loop_start()
def on_connect(self, client, userdata, flags, rc):
print("Connected with result code " + str(rc))
client.subscribe("robot/signal")
def on_message(self, client, userdata, msg):
# Update message_data with the received MQTT message.
self.message_data = msg.payload.decode()
print("Received message: " + self.message_data)
# Safely expire the component solution on the main thread.
try:
ghenv.Component.ExpireSolution(True)
except Exception as e:
self.message_data = "Error expiring solution: " + str(e)
def RunScript(self, x, y):
# When the component is executed, check if a new MQTT message was received.
output = "Hello Python 3 in Grasshopper! Subscription active."
if self.message_data:
output = self.message_data
print(output)
return output
But Rhino immediately crashes. Any suggestions why?
