Connecting points with line and edit the way they are connected
I am trying to construct 9 points on XY plane and another 9 points on XY plane with Z. So the way I need the first XY plane to connect with the other XY plane above is with a lofted circle (Line for now). I managed to construct points I needed but I don’t know how I would shift the connection in an editable way.
The points in the file are not 1-9, it starts from 0-3 then repeat itself in each row.
I need the line to be connected to each point in a controlled way (let’s say X+1). The attached image demonstrates what exactly I mean.
Hope that’s clear.
Thanks
CONNECTED POINTS.gh (18.5 KB)
Firstly the nature of GH is of data trees so you don’t need to repeat parts of the definition twice. You can do something like this:
Connect.gh (6.7 KB)
To shift you can use shift list like this:
Shift Connect.gh (8.5 KB)
Thanks very much for your help that’s exactly what I was looking for.
In fact i didn’t know about the “Entwine” and also Flatten part of construct point.
