I’m trying to panel a parametric tower by connecting points along the surface into triangles but I’ve hit 2 issues that I can’t seem to fix.
The first problem is that I can’t figure out how to connect the first and last point of each level together so there is currently a gap in the facade running the length of the tower.
And the second is that the top and bottom level curve points are connecting up so the facade loops around which I don’t want.
I assume I’ve messed up my lists but I’m not sure where exactly I’ve gone wrong, any ideas? I’ve highlighted the area where I believe I’ve gone wrong in the grasshopper file.
