Hi all–
I am attempting to connect two sets of points. I’ve used the point components and attached them to the line component.
What I would like is to attach every point in the first set to every point in the second. When I set multiple points for each component, the list numbers connect to each other:
When I set only a single point from the first set, it is able to connect to all of them.
What I am hoping for is to set up a script where I can get this to happen with every single point (connecting the each of the first set of points to every pint in the second). I suspect this might be solved with a List Item but cannot figure it out. Any tips helpful thank you!
ConnectPoints2.gh (528 Bytes)
Mining_Test.3dm (53.8 KB)
