I would like for this object in the pink (a planter box) to sit on the surface in red. Is there a command that would allow me do that? I’ve tried just using the gumball to lower it down but I am curious if there is a better way.
Thanks!
Have you tried the OrientOnSrf command? I keep forgetting it exists but it’s honestly so good for this. You can place your object right onto a surface and it’ll snap to the curvature automatically. Way more reliable than wrestling with the gumball for this kind of thing.
There’s a good video explaining it here: https://youtu.be/s065xooEJA8?si=NyTakPQEtUgRMOlF
Let me know if it works!
-Robert
the move command with an osnap for near is likely what you want.
or change gumball to “snappy” in the gumball setting and use a snap after relocating the gumball to a bottom corner.
this worked perfectly! thanks!
