Im trying to connect multiple points at once with the line component, but i am struggling to figure out how to use the lists to build each connection.
I have a surface that i subdivided and debrepped, as i understand each face i deconstructed is a branch that i can connect up individually. In this case I took the edges of each face and halved each line, so i could obtain the midpoints. Any idea how i can efficiently add up each halfway point?
Dear Harry, Your example .gh is loaded with plugins. I do not want to install them.
So please provide a small example of the question you have.
Internalise the geometry close to that area. do not use plugin (unless it is a question about that plugin itself).
Ah I see. I tried to open the file to help but I don’t have Karamba or Kiwi. Also its seems like you have a lot of geometry that is not internalized.
I don’t particularly like using Lunchbox for penalization anymore since it tends to be very heavy and behaves weirdly sometimes.
If you don’t know how to use it, it can be a bit weird to wrap your head around, but in my opinion, ‘Relative Item’ is by far the most useful component to learn when it comes to penalization.
