I created this Hex mesh in MatrixGold Jali and applied SubD MultiPipe to it, and got this result because the endpoints of each curve are not touching. I can do it manually by snapping each point to the one next to it, but it will take forever.
Is there a way to do it in Grasshopper?
Jali has the option to ignore the UV coordinate of a twisted surface and doesn’t stretch the pattern; is there a way to achieve that in Grasshopper?
Thanks
you can try using some Jedi tricks like this:
Jedi_Trick.gh (17.4 KB)
you’ll need to find the correct Tolerance value playing with the slider in order to let neighbor points average into just one
