Connecting curves using the fillet component
I want to make the picture on the left look like the picture on the right.
I’m using the fillet component, but it doesn’t work. Is there another way?
Fillets make rounded corners. You want square corners. Don’t use fillets.
At each corner get the X & Y values of each line endoint. Then make a new point using the X value from one line and the Y value from the other. This will produce 4 new points, one at each corner. Then create a polyline from the 4 points.
This will work if all your lines are oriented the same way.
ConnectCorners.gh (7.9 KB)
thank you. This is exactly what I wanted!
감사합니다! fillet이 둥근 모서리만 가능한 것 인줄 몰랐습니다.
Unfortunately that will displace the sloping line.
