Connecting arcs in one direction only
Given the 2 arcs (red lines) in the picture, i would like to connect them together by using the green lines. However, i want the green to go strict to the Y direction. So it needs to be like in the second picture. Any way to do this?
Connected arcs.gh (7.0 KB)
Here is a solution to the problem, probably there are smarter ones :slight_smile:
the ends of the arcs connected together regardless of their position
other division lines travel +Y from arc B until they intersect arc A
Connected arcs.gh (16.9 KB)
Hmm… Looks alright.
is there any way to make it more parametric by using Genepool?
For some reason i get 2 lines maximum. Probably doing something wrong…
Connected arcs 2.gh (21.1 KB)
here it is
Connected arcs 2_re.gh (18.2 KB)
Thanks a lot! :slight_smile:
HI,
Instead of offset curve just move the curve and make point s and create line it be more accurate .!
i think !
cheers
rajeev
