Connect two conrtol points along curve
I am wondering if there is any way to easily connect these two control points by copying the curve they are both snapped to? I’m trying to use the push/pull command to create a relief design on the surface but since these curves are still open it won’t select the surface in between the curves instead it only selects the entire area within the closed curve!
If you’re looking to make closed curves from different curves, use CurveBoolean. I wouldn’t recommend using push/pull for anything with complex curves.
copy the curve, split (use the point option in the command line) where you want to make that curve segment, then join that segment to your other segment to make a close area. Push pull relies on close areas to ID the area to be pushed or pulled.
