Connect solid
Hi, I want to make meshes covering solids like picture. But I don’t know how to connect.
would you tell me how to make it?
Solid.3dm (179.1 KB)
You can determine the edge lines with the DupEdge command and combine them with the Loft command.
Hello - a Line between the edges and Sweep2 ought to work OK. You will need to use the AddSlash button in Sweep2 to help true up the sweep - probably four or five will be enough.
Thank you so much!
Hello pascal, I’m Using sweep2, but there’s something wrong. I couldn’t figure it out. Can you tell me what is the problem?
Hi Ryu - hard to say from your picture, but it might be easier to DupFaceBorder the top and bottom faces you are connecting, and then hide the solids and just use the border curves. Connect them with one or more straight lines and make the sweep from those, plus AddSlash if the surface twists more than you like.
Thank you! It worked!! :grinning:
